3CX and Data Base PostgreSql
Discussion in '3CX Phone System - General' started by inter-rupteur, Feb 13, 2009.
  1. inter-rupteur
    Feb 9, 2009
    15
    Hi everybody,
    i have a question about 3CX and PostgreSql ! I want to know if it's possible to migrate data base in another real serveur ? One serveur for 3CX system and one serveur for postgresql : i want to optimize each serveur... I searched something about this on the forum but i can't find this !!
    Thanks a lot for your help !
    Inter-Rupteur
  2. inter-rupteur
    Feb 9, 2009
    15
    YESSSSSSSSSSSSSSSSSSSSSSSSSSSS !! It's Possible !!! It becomes very interesting !!! :mrgreen:
    I will keep you posted.
    Inter-Rupteur
  3. Henk
    Henk Member
    Nov 13, 2007
    250
    Should be doable, change the correct Progress files as they currently point to localhost.
    have not tried it but looking at the config files it should be possible, simply not to keen to try it myself at the moment.
    H.
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    278
    Why would you want to do that? Postgres does not take much processor time, is very compact and as such its fine to run it on the phone system server itself?
  5. inter-rupteur
    Feb 9, 2009
    15
    yes it's possible without problem Henk !
    for Admin => it's not for that reason, but for Failover ! I want to dissociate db, phonesystem, etc... If the server fails, what can i do : except for my eyes to cry... look at my other post which explains what I want to do :
    http://www.3cx.com/forums/about-load-balancing-in-3cx-8966.html
    Inter-Rupteur
