3CX and DB interface
Discussion in '3CX Phone System - General' started by manolo-ehc, Jun 20, 2011.
  1. manolo-ehc
    Aug 10, 2009
    Is it possible to have 3CX connected to any DB like SQL, so (p.e.) when a caller input a number we can search in the DB and present the result information related to that number?? if so how can we do that? any additional app or interface??
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    You can access the database via ODBC Connection.
    With this you can write an application to do as you like
    or use MyPhone to notify an external program on a incoming call.
  3. danielrve
    Oct 5, 2011
    Hi Guys!!!
    How I configure this? I Know how to create a DNS for ODBC but how put this in the 3CX interface??
    I wish to cofigurate the IVR for consulting a data for a Database (MSSQL,MySQL,PGSQL), send information like ID or Number or something, It's Possible?
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    You can use 3CX VAD (Voice application designer) to achieve your goals.
