3CX and FaxBack or any outbound fax solution
Discussion in '3CX Phone System - General' started by DexDeadly, Oct 22, 2013.
  1. DexDeadly
    Dec 12, 2012
    55
    Anyone use this setup? If so how did you configure the system? They state its free for just using it as outbound with MS Fax Server. However I do not really see any documentation anywhere for this. Who has this working or what is your best outbound fax solution? Please let me know, I love 3CX and have everything else working wonderfully as well as incoming faxes. This is my last thing I need to setup.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    3cx does not provide an outbound fax solution built in. You would need a Fax Machine and an ATA Adapter...
    Alternative: http://www.myfax.com/
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    466
    77
    You can use most fax machines and fax modems connected to a T.38 compatible ATA along with a T.38 compatible voip trunk. I have this working at several customers. ATA's used Linksys 3102 and Grandstream HT702. VoIP provider Babytel.
    I have also tried using T.38 compatible ATA with T.38 compatible FXO (Patton) and not been successful getting faxes to go out (Something with Analog-Voip-Analog doesn't seem to work.
  4. bardissi
    bardissi Member
    Jan 31, 2012
    318
    t.38 or g711 stinks for fax.
    We used https with audiocodes adapters.
    Works like a charm.
