3CX and Faxing
Discussion in '3CX Phone System - General' started by TwigsUSAN, Feb 14, 2007.
  1. TwigsUSAN
    Jan 31, 2007
    45
    I'm guessing I know what your answer is going to be, but I figure I would ask anyways. I was wondering if 3CX can handle sending/receiving faxes at the moment. For example, I am looking at getting a second VOIP provider that can handle, I believe, the T.38 protocol for faxing. I would like the 3cx system to distribute the faxes appropriately, possibly straight to a printer. If not, is this a feature that you are looking into for future releases.
    Thanks,
    Ralph
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    We do not support that currently.
  3. TwigsUSAN
    Jan 31, 2007
    45
    Thats what I figured, but I thought I would ask anyways. Thanks for the reply.
