3CX and Intervoice Brite IQtalk IVR integration
Discussion in '3CX Phone System - General' started by kylejoe1, Apr 1, 2011.
  1. kylejoe1
    Feb 15, 2011
    66
    Anyone know how to integrate 3CX with an existing banking IVR residing on another server such as the Intervoice / Brite IQTALK IVR without using a PSTN gateway in between? Can it work over straight network connection if incoming calls coming into 3CX are from a VOIP SIP Provider? Is it as easy as adding the other IVR server as a VOIP provider or extension, etc...?
    The Intervoice/Brite IVR works with Avaya over a DS1 card with a ethernet cable going from the IVR to the Avaya PBX.
    Ex. the other IVR asks for account number/SSN/password then asks user....
    Press 1 for share balances
    Press 2 for loan balances
    etc....
  2. danacclaim
    May 17, 2011
    You will need a PSTN gateway to integrate VoIP with the InterVoice-Brite IQ-Talk system. :(
