3cx and iphone 4 tunneling? how?
Discussion in '3CX Phone System - General' started by equintana, Feb 12, 2011.
  1. equintana
    Dec 20, 2010
    57
    I need to stablish a secure tunnel between my 3cx a iphone4 devices. Could I use the tunneling option? is possible to configure tunneling with iphone 4?
    regards
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    I don’t believe that the tunnel option is currently supported on the I Phone.
    I certainly don’t have the option on my I Phone
  3. leejor
    10,360
    226
    It sounds like the tunnelling option is in the works for the next release of "portable" versions of the 3CX phone. In the meantime, if you have a VPN server, you could try running that. When I considered the iPhone I recall it being able to run VPN, just not a version of PPTP that worked for me.
  4. equintana
    Dec 20, 2010
    57
    Ok... I will wait for this event
    regards
