3CX and MS SQL
Discussion in '3CX Phone System - General' started by dyntech, Oct 2, 2007.
  1. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Has anyone had any trouble with both of these running on the same server?
    I had 3CX running fine, upgraded SQL express to the full version of SQL 2005 and can't get SQL services to run!
    Anybody else seen anything like this?
  2. dlrmartin
    Jul 26, 2007
    15
    no one issue here.
  3. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    I do not believe that 3CX is the cause of this problem. After several hours of working with it, I think the problem is SQL itself.
