3CX and MSN/DID Numbers
Discussion in '3CX Phone System - General' started by john_pansters, Apr 9, 2009.
  1. john_pansters
    Mar 8, 2009
    We are having problems with MSN numbers and 3CX
    After entering MSN numbers in 3CX ( Using DID Name/Number we have the problem that on the Phone display the IP adress and portnummer of the 3CX server is displayed instead of the number of the calling person. Incoming Voip calls display the correct number.
    Routing of the MSN numbers to the Phones works correctly.
    Configuration is 2 x Patton 4554 for the ISDN Lines ( With 8 MSN Numbers )
    3CX with Grandstream 2020 telephones
    3 incoming / outgoing Voip Lines
    Any suggestion where I made a mistake
    Thanks, John
  2. matictec
    matictec New Member
    Mar 31, 2008
    188
    this can be solved by changing the incoming sip-fields for the pstn.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,913
    215
    Are these DID numbers on the ISDn lines and on the patton gateway? If not this should work out of the box. I suggest opening a support ticket with our support portal
