3CX and musimi, no sound on incoming calls
Discussion in '3CX Phone System - General' started by Dark One, Dec 11, 2007.
  1. Dark One
    Dec 11, 2007
    9
    I have a setup with 3CX and musimi VOIP provider.
    I have opened UDP for stun, sip and rtp ports according to my PBX setup.
    Ringing out makes no problem and all works, so does internal calls.
    But when i cal from my cell to the sip number, i can make connection but there are no sound throug the line.
    I obviously have made some error :)
    Any ideas?
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Witch ports (how many) have you opened?
    List of default ports used by the 3cx phonesystem:
    5060 (stanard sip port) TCP/UDP
    5061 (secondary sip port) TCP/UDP
    5480 (portgre) (only on local machine)
    5481 (apache) (only on local machine)
    5482 (media server) (only on local machine)
    3478 (STUN Server) TCP/UDP
    7000-7500 (Default port for internall calls) (only on local machine)
    9000 - 9003 (ports for external calls through VOIP Gateway) UDP
    10000-20000 (RTP ports) (Used if no stun available for audio)
  3. pbnet
    Oct 25, 2007
    12
    Re:
    Have the same problem. No ringing tone/music on hold when I dial inside numbers. No problem for outbound calls.
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
    please give us the call related part of the incomming call and a example for a outgoing "good" call from your server log.
    perhaps we can see what happens.
    Andy
  5. Dark One
    Dec 11, 2007
    9
    I have opened following ports in ISA
    3874 tcp -outbound
    3874 udp send/rec
    5060 - 5062 tcp -outbound
    5060 - 39999 udp send/rec
    that should cover the ports quite well
    Allow non-sequental RTP port is set to check
    i still can't figure it out.
    What log files do i need to check ?
  6. Mori
    Mori New Member
    Mar 23, 2007
    223
    This should be 3478 for STUN, not 3874.
  7. Dark One
    Dec 11, 2007
    9
    well unfortunately the fault was in my post, not on my firewall :(
    So i have actually opened 3478 in ISA both tcp and udp
    And i get no stun errors.
    Maybe my provider does not use stun ?
    What options do i have if no stun ?
  8. Mori
    Mori New Member
    Mar 23, 2007
    223
    If your provider does not have stun you can use 3cx's.
    stun.3cx.com
    stun1.3cx.com
    It does not make a difference as long as you use the same stun in all your phones and PBX.
