3CX and Nokia: outgoing Calls OK, but not the incoming calls
Discussion in '3CX Phone System - General' started by econcept, Nov 15, 2012.
  1. econcept
    Nov 2, 2012
    Hello everybody,
    I have recently set up my 3CX server. For the moment, with 3CXPhones, everything works well, incoming calls as outgoing calls.
    I created an extension to be able to connect my Nokia 701 when I am away from the office.
    I followed this tutorial step by step (the menu of parameters on the 701 is almost the same as on the N95):
    http://www.3cx.com/sip-phones/nokia.html
    For outgoing calls, it works well, nothing to add.
    But for incoming calls, it doesn't function, neither internal calls, nor external calls.
    In internal call, if I call the extension of my Nokia 701 from a 3CXPhone, the latter answers me "Forbidden".
    Here an extract of my logs, corresponding to a call attempt from the 3CXPhone to my 701:
    If somebody has an idea where from comes the problem... Thank you in advance!
    Best Regards,
    David
    PS : Sorry for my poor english, I'm french (but I haven't had a response on the french forum... :( So I'm posting here...)
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Re: 3CX and Nokia: outgoing Calls OK, but not the incoming c
    08-nov.-2012 09:45:47.388 Call to T:Extn:110@[Dev:sip:CfIui-lHGz5C74Blm3ab@xx.xxx.xxx.xx:5060;transport=UDP] from L:4.1[Extn] failed, cause: Cause: 603 Decline/INVITE from 192.168.10.1:5060
    Nokia 701 rejects the incoming call.
    You need to ask developer of SIP client running on this phone.
  3. econcept
    Nov 2, 2012
    Thank you for your answer.
    However, there is one thing I do not understand:
    If I configure my VOIP line directly on my nokia, it works very well. I can call and receive calls without any problems
    It's only when my VOIP line is on the 3CX server and the nokia is connected to a 3CX extension that I can no longer receive calls...
    Below is the detailed log, if it can provide more info (xx.xxx.xxx.xx is my public IP) :
    Code:
    16-nov.-2012 09:07:17.107	L:9.1[Extn]: Terminating targets, reason:
    16-nov.-2012 09:07:17.106	Leg L:9.1[Extn] is terminated: Cause: BYE from PBX
    16-nov.-2012 09:07:17.106	Terminated from "E-Concept Applications"<sip:100@ECA-SERVEUR:5060>;tag=b422414f to <sip:110@ECA-SERVEUR:5060>;tag=92670a68; reason: Rejected
    16-nov.-2012 09:07:17.106	L:9.1[Extn] Sending: OnSendResp Send 403/INVITE from 0.0.0.0:0 tid=a00f6e741368852c Call-ID=MDEyYTk1OTJjYTg1ZWU2NWViZWM1MDRlNDYwNDkwNzE.:
    			SIP/2.0 403 Forbidden
    			Via: SIP/2.0/UDP 192.168.10.20:53731;branch=z9hG4bK-d8754z-a00f6e741368852c-1---d8754z-;rport=53731
    			To: <sip:110@ECA-SERVEUR:5060>;tag=92670a68
    			From: "E-Concept Applications"<sip:100@ECA-SERVEUR:5060>;tag=b422414f
    			Call-ID: MDEyYTk1OTJjYTg1ZWU2NWViZWM1MDRlNDYwNDkwNzE.
    			CSeq: 2 INVITE
    			Warning: 499 ECA-SERVEUR "Forbidden"
    			Content-Length: 0
    16-nov.-2012 09:07:17.106	SendMsg from <sip:110@ECA-SERVEUR:5060>;tag=92670a68 to "E-Concept Applications"<sip:100@ECA-SERVEUR:5060>;tag=b422414f
    16-nov.-2012 09:07:17.058	Call(C:9) is terminated
    16-nov.-2012 09:07:17.056	[CM503020]: Call(C:9): Normal call termination. Call originator: Extn:100. Reason: Forbidden
    16-nov.-2012 09:07:17.056	[CM503016]: Call(C:9): Attempt to reach <sip:110@ECA-SERVEUR:5060> from Extn:100 has failed. Reason: Forbidden
    16-nov.-2012 09:07:17.056	[Flow] Endpoint Extn:110 has no forwarding rule on reason 'Forbidden'
    16-nov.-2012 09:07:17.052	[Flow] Current call diversion path:[]
    16-nov.-2012 09:07:17.052	L:9.1[Extn] failed to reach Extn:110, reason Forbidden
    16-nov.-2012 09:07:17.052	RerouteReq
    16-nov.-2012 09:07:17.051	L:9.2[Extn]: Terminating targets, reason: SIP ;cause=603 ;text="Decline"
    16-nov.-2012 09:07:17.051	Leg L:9.2[Extn] is terminated: Cause: 603 Decline/INVITE from 192.168.10.1:5060
    16-nov.-2012 09:07:17.051	L:9.2[Extn] got Terminated Recv 603/INVITE from 192.168.10.1:5060 tid=7d75aa465100e056 Call-ID=ZjM3Y2MzN2Q4MTc1YWQ2NzJjNDViMTFkNmQzZGYyYTc.:
    			SIP/2.0 603 Decline
    			Via: SIP/2.0/UDP 192.168.10.200:5060;branch=z9hG4bK-d8754z-7d75aa465100e056-1---d8754z-;rport=5060;received=xx.xxx.xxx.xx
    			To: <sip:110@xx.xxx.xxx.xx>;tag=8bc5d6tcm1hc61gudk88
    			From: "David MARTINET"<sip:100@192.168.10.200>;tag=1f64dd06
    			Call-ID: ZjM3Y2MzN2Q4MTc1YWQ2NzJjNDViMTFkNmQzZGYyYTc.
    			CSeq: 1 INVITE
    			Content-Length: 0
    16-nov.-2012 09:07:17.051	Terminated from <sip:110@xx.xxx.xxx.xx>;tag=8bc5d6tcm1hc61gudk88 to "David MARTINET"<sip:100@192.168.10.200>;tag=1f64dd06; reason: Error
    16-nov.-2012 09:07:17.051	~Target=Ext:Ext.110
    16-nov.-2012 09:07:17.051	~Route=Dev:sip:CfIui-lHGz5C74Blm3ab@xx.xxx.xxx.xx:1024;transport=UDP
    16-nov.-2012 09:07:17.051	Call to T:Extn:110@[Dev:sip:CfIui-lHGz5C74Blm3ab@xx.xxx.xxx.xx:1024;transport=UDP] from L:9.1[Extn] failed, cause: Cause: 603 Decline/INVITE from 192.168.10.1:5060
    16-nov.-2012 09:07:17.050	L:9.2[Extn] got Failure: Failure Recv 603/INVITE from 192.168.10.1:5060 tid=7d75aa465100e056 Call-ID=ZjM3Y2MzN2Q4MTc1YWQ2NzJjNDViMTFkNmQzZGYyYTc.:
    			SIP/2.0 603 Decline
    			CSeq: 1 INVITE
    			Content-Length: 0
    16-nov.-2012 09:07:17.050	[CM503003]: Call(C:9): Call to <sip:110@xx.xxx.xxx.xx:5060> has failed; Cause: 603 Decline/INVITE from 192.168.10.1:5060
    16-nov.-2012 09:07:17.050	Session 6673 has failed in leg L:9.2[Extn] ; Cause: 603 Decline/INVITE from 192.168.10.1:5060
    16-nov.-2012 09:07:17.050	Failure from <sip:110@xx.xxx.xxx.xx>;tag=8bc5d6tcm1hc61gudk88 to "David MARTINET"<sip:100@192.168.10.200>;tag=1f64dd06
    16-nov.-2012 09:07:14.813	[CM503025]: Call(C:9): Calling T:Extn:110@[Dev:sip:CfIui-lHGz5C74Blm3ab@xx.xxx.xxx.xx:1024;transport=UDP] for L:9.1[Extn]
    16-nov.-2012 09:07:14.813	Route to L:9.2[Extn] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=775fbe312702103b Call-ID=ZjM3Y2MzN2Q4MTc1YWQ2NzJjNDViMTFkNmQzZGYyYTc.:
    			INVITE sip:CfIui-lHGz5C74Blm3ab@xx.xxx.xxx.xx:1024;transport=UDP SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-775fbe312702103b-1---d8754z-;rport
    			Max-Forwards: 70
    			Contact: <sip:100@192.168.10.200:5060>
    			From: "David MARTINET"<sip:100@192.168.10.200:5060>;tag=1f64dd06
    			CSeq: 1 INVITE
    			Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    			Content-Type: application/sdp
    			Supported: replaces
    			Content-Length: 408
    			v=0
    			o=3cxPS 323246620672 454511558657 IN IP4 192.168.10.200
    			s=3cxPS Audio call
    			c=IN IP4 192.168.10.200
    			t=0 0
    			m=audio 7032 RTP/AVP 0 8 3 13 9 18 110 99 101
    			a=rtpmap:0 PCMU/8000
    			a=rtpmap:8 PCMA/8000
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    			a=rtpmap:9 G722/8000
    			a=rtpmap:18 G729/8000
    			a=fmtp:18 annexb=no
    			a=rtpmap:110 iLBC/8000
    			a=rtpmap:99 SPEEX/8000
    			a=rtpmap:101 telephone-event/8000
    			a=sendrecv
    16-nov.-2012 09:07:14.802	Outbound URI is used: sip:CfIui-lHGz5C74Blm3ab@192.168.10.1:5060;transport=UDP
    16-nov.-2012 09:07:14.802	SLA is globally disabled
    16-nov.-2012 09:07:14.798	Added leg L:9.2[Extn]
    16-nov.-2012 09:07:14.770	[Flow] Call(C:9): making call from L:9.1[Extn] to T:Extn:110@[Dev:sip:CfIui-lHGz5C74Blm3ab@xx.xxx.xxx.xx:1024;transport=UDP]
    16-nov.-2012 09:07:14.770	[CM503027]: Call(C:9): From: Extn:100 ("E-Concept Applications" <sip:100@ECA-SERVEUR:5060>)  to  T:Extn:110@[Dev:sip:CfIui-lHGz5C74Blm3ab@xx.xxx.xxx.xx:1024;transport=UDP]
    16-nov.-2012 09:07:14.770	[CM503004]: Call(C:9): Route 1: from L:9.1[Extn] to T:Extn:110@[Dev:sip:CfIui-lHGz5C74Blm3ab@xx.xxx.xxx.xx:1024;transport=UDP]
    16-nov.-2012 09:07:14.770	[Flow] Endpoint Extn:110 has no forwarding rule on reason 'All calls'
    16-nov.-2012 09:07:14.769	[Flow] Call(C:9): has built target endpoint: Extn:110 for call from L:9.1[Extn]
    16-nov.-2012 09:07:14.769	[Flow] Target endpoint for 110 is Extn:110
    16-nov.-2012 09:07:14.769	[Flow] Building target endpoint to 110 from "E-Concept Applications" <sip:100@ECA-SERVEUR:5060>
    16-nov.-2012 09:07:14.769	[CM503010]: Call(C:9): Making route(s) from Extn:100 to <sip:110@ECA-SERVEUR:5060>
    16-nov.-2012 09:07:14.769	Remote SDP is set for leg L:9.1[Extn]
    16-nov.-2012 09:07:14.769	OnOffer from "E-Concept Applications"<sip:100@ECA-SERVEUR:5060>;tag=b422414f
    16-nov.-2012 09:07:14.768	[CM505001]: Endpoint Extn:100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.26523.0] PBX contact: [sip:100@192.168.10.200:5060]
    16-nov.-2012 09:07:14.768	Inbound DID: ''; Phonebook Name: ''
    16-nov.-2012 09:07:14.766	[CM500002]: Call(C:9): Info on incoming INVITE from Extn:100:
    			Invite-IN Recv Req INVITE from 192.168.10.20:53731 tid=a00f6e741368852c Call-ID=MDEyYTk1OTJjYTg1ZWU2NWViZWM1MDRlNDYwNDkwNzE.:
    			INVITE sip:110@ECA-SERVEUR:5060 SIP/2.0
    			Max-Forwards: 70
    			Contact: <sip:100@192.168.10.20:53731;rinstance=9ae73002c33c4055>
    			CSeq: 2 INVITE
    			Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="414d535c06b6853283:a2b0edec8c5a5577fa837c80981d1dba",uri="sip:110@ECA-SERVEUR:5060",response="0f3d11968b7f6ce509ce79ca3bafeb30",algorithm=MD5
    			Supported: replaces
    			User-Agent: 3CXPhone 6.0.26523.0
    			Content-Length: 282
    			v=0
    			o=3cxVCE 197124960 220284180 IN IP4 192.168.10.20
    			s=3cxVCE Audio Call
    			t=0 0
    			m=audio 40044 RTP/AVP 0 8 3 101
    			a=rtpmap:3 GSM/8000
    			a=fmtp:101 0-15
    			a=ptime:20
    			a=sendrecv
    16-nov.-2012 09:07:14.765	[CM503001]: Call(C:9): Incoming call from Extn:100 to <sip:110@ECA-SERVEUR:5060>
    16-nov.-2012 09:07:14.749	Outbound URI is used: sip:100@192.168.10.20:53731;rinstance=9ae73002c33c4055
    16-nov.-2012 09:07:14.748	IncomingCall: C:9 from <sip:100@ECA-SERVEUR:5060> to <sip:110@ECA-SERVEUR:5060>
    16-nov.-2012 09:07:14.748	Added leg L:C:9.1[No endpoint yet]
    16-nov.-2012 09:07:14.748	UasSession 6670 started
    16-nov.-2012 09:07:14.748	Call from "E-Concept Applications"<sip:100@ECA-SERVEUR:5060>;tag=b422414f to <sip:110@ECA-SERVEUR:5060>;tag=92670a68
  4. leejor
    10,587
    253
    Cause 603 Decline:= Called party was contacted but does not want to take part in the call.
    You may need to enlist the help of a program like Wireshark to get more details on what is being sent to the phone that is causing it to "reject" the call. It obviously doesn't like something.
