3CX and Outlook Plugin Failed
Discussion in 'CRM / Helpdesk / App Integration' started by IT_S, Apr 3, 2018.
  1. IT_S
    Dec 20, 2017
    18
    I am trying to install Outlook Plugin in a Windows 7 x64 with Outlook 2013.
    Everything is ok but when I try to start Outlook I have an error with the VSTO not valid or file could not be opened. Do you have any ideas on what is wrong ?
    For your information , users are not admin of the computer... And Trying also to deploy on Golden Image.
    Regards
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,351
    108
    Hello @IT_S,
    You don't need to be an admin to install the add-in, because it is registered for the current user only.
    This might happen if you use an old version of 3CXPlugins. Please try downloading the latest installer from here:
    https://downloads.3cx.com/downloads/3CXPlugins15.exe
    Kind regards.
