3CX and Patton 4554 inbound calls
Discussion in '3CX Phone System - General' started by dik, Jul 1, 2008.
  1. dik
    dik
    Jul 1, 2008
    5
    We are using a 3CX V6 with Patton 4554.
    Connected is one ISDN2 line serving 4 phone numbers.
    When an incomming call to either number comes in, the patton responds and transfers the call to the 3CX (as expected).
    The question is how should we change the configuration of the patton to only respond to one phone number?
    This is our first experience with these products so we are still learning......
  2. Spyklee
    Nov 1, 2007
    45
    Hi dik,
    You need to configure the MSN number of the ISDN in a specific defined line in 3CX not the Patton.
    In version v5 you need to specify DID/DDI number/mask attribute for this.
    Hope this helps,
    Cheers! Eric
  3. dik
    dik
    Jul 1, 2008
    5
    Hi Eric,
    Could you be more specific on where to set this MSN?
    I was not able to find th field you specified in V6.
    Thanks,
    Dik
  4. Spyklee
    Nov 1, 2007
    45
  5. dik
    dik
    Jul 1, 2008
    5
    I tested the DID function, which seems to work. It was possible to have a call to a specific number to end up in different voicemail boxes (what we used for th test) or any other 3CX function for that matter.
    However if we call a number which is not used in a DID rule, still the standard call-group is used. Any suggestions how to avoid this, as we would like some numbers NOT to be handled by the 3CX.
  6. Spyklee
    Nov 1, 2007
    45
    I see your point, do you handle these calls with an other system?
    If not you could define a DID and end the call directly.
    Cheers, Eric
  7. dik
    dik
    Jul 1, 2008
    5
    Eric,
    Yes, these calls are handled with another system.
    Tnks
    Dik
  8. Spyklee
    Nov 1, 2007
    45
    Dik,
    Just to let you know that I didn't find anything to configure it on the Patton. Do you use the Patton as gateway for that specific msn or should it be bypassed?
    Eric
  9. dik
    dik
    Jul 1, 2008
    5
    Eric,
    That patton is together with another device connected to a NT1(point to multi-point), the patton should handle one number, the other device another number.
    The other device works without problems
    Dik
  10. tomaz
    Feb 27, 2008
    12
    I have the same problem. I have done some tests, but I believe that problem is in Patton.
    I can not configure Patton to pass MSN information to 3CX PBX.
    It is very comon situation. One MSN line / number should be handled by 3CX, another is directed to analog fax.
  11. silvano
    Sep 27, 2008
    5
    I have the same situation: one MSN must be handled by an analog FAX. I solved the problem configuring the FAX DID to end the call on 3CX V6. This way the call is ignored by 3CX and so it can be picked up by the FAX machine.
  12. FITEC
    Sep 15, 2008
    19
    i solved it by forwarding the MSN DID to the outside (same) number?!
