3CX and recommended audio codecs
Discussion in '3CX Phone System - General' started by M Knauf, Sep 7, 2017.
  1. M Knauf
    Apr 22, 2010
    Hi there,
    we´re using 3CX v15.5.1694.0 on a Windows Server 2012R2.
    Also there is a Beronet Gateway with a PMX connection and
    we´ve about 40 extensions configured in 3CX.
    At the moment we´re switch from Snom 320/360 phones to
    the 3CX Softphone and we´re using Jabra Evolve 40 cable
    headsets. So far the quality of voice is good. But sometimes
    there are problems.
    Which are the recommended audio codecs for such a configuration?
    A) Jabra Headsets with 3CX Softphone AND Snom 320/360 phones.
    B) Only Jabra Headsets with 3CX Softphone (planned for near future).
    Does it make sense to enable "PBX Delivers Audio"?
    Any other hints about this scenario?
    Thank you so much.
    Markus
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Use PCM-A / PCM-U (G.711a / G.711u) codec in your local area network and for Beronet gateway. It provides the necessary quality for your communications in your LAN. Enabling PBX delivers audio for phones in the local-area network makes no difference. If you are still experiencing problems you should investigate your network for issues.
  3. leejor
    10,758
    286
    Generally, only as a last resort, as this will put an increased load on the server.
