3cx and several nics
Discussion in '3CX Phone System - General' started by funnycoder, Sep 11, 2012.
  1. funnycoder
    Sep 11, 2012
    Hello, we started using 3pbx several weeks ago. It works perfect, but we have one question.
    We have 3 pbx windows server with 4 nics.
    How can we configer outbound calls to be routed through a cdifferent nics.
    For example.
    3 pbx nic one - 192.168.0.10
    3pbx nic two - 192.168.0.11
    3pbx nic three - 192.168.0.12
    3pbx nic four - 192.168.0.13
    We need :
    User 1 outgoing calls should be made throug nic one
    User 2 outgoing calls should be made throug nic two
    User 3 - nic three
    User 4 - nic four
    By the way - the operator is same for the all user, so adding static route to operators ip address can not be a solution.
    Thanks a lot for any help!
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    I am not sure I understand the question. It seems that you have 3 different servers running 3CX and between the 3 servers there are 4 NICs? "We have 3 pbx windows server with 4 nics."
    Can your provide more detail?
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,397
    273
    I think he meant a 3cx server with 4 nics. what would be the point of using a different nic for each user?
    3cx has trouble with more than 1 nic - I do not recommend it.
  4. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    3CX can work quite well with 2 NICs when one is public and one is private, but to have 4 NICs on the same private subnet is quite ridicoulus.
    Assuming that they all run at 100Mbps ONLY, each card can handlye about 1500 concurrent phone calls (w G711). I think you will need to review your architecure a bit.
  5. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    We have run into several problems where multiple NIC's are involved on a 3CX server. Remember that SIP header info has to determine routing & endpoints, so multi-NIC's just make this confusing. Where I had 2 NIC's on a server, I had to disable one to get consistent call connection & quality.
    Keep it simple ...
    Graham Hill
    Foxhall Solutions
