3cx and skype sip setup
Discussion in '3CX Phone System - General' started by kyc_cds, Jan 9, 2011.
  1. kyc_cds
    Jan 9, 2011
    i am attempting to setup the c3x pbx system to try before i buy, but i am having trouble with both inbound and outbound calls. any extension internally works fine, but i cant call any out side numbers and when you call inbound using my online number you get a busy signal. i setup up skype connect to test the system with. here is the long when i try to make an inbound call
    23:21:15.046 [CM503020]: Normal call termination. Reason: Not found
    23:21:15.046 [CM503016]: Call(9): Attempt to reach <sip:**********@192.168.2.3> failed. Reason: Not Found
    23:21:15.031 [CM503003]: Call(9): Call to sip:40*******@sip.skype.com:5060 has failed; Cause: 404 Not Found; from IP:63.209.144.201:5060
    23:21:13.062 [CM505003]: Provider:[Skype for SIP - Worldwide] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:99051000126312@69.63.89.218:5060]
    23:21:13.062 [CM503002]: Call(9): Alerting sip:99051000126312@sip.skype.com:5060
    23:21:12.031 [CM503025]: Call(9): Calling VoIPline:40*******@(Ln.10000@Skype for SIP - Worldwide)@[Dev:sip:99051000126312@sip.skype.com:5060]
    23:21:11.921 [CM503004]: Call(9): Route 1: VoIPline:40*******@(Ln.10000@Skype for SIP - Worldwide)@[Dev:sip:99051000126312@sip.skype.com:5060]
    23:21:11.921 [CM503010]: Making route(s) to <sip:**********@192.168.2.3>
    23:21:11.921 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for iPhone 1.0.18] PBX contact: [sip:100@192.168.2.3:5060]
    23:21:11.890 [CM503001]: Call(9): Incoming call from Ext.100 to <sip:**********@192.168.2.3>
    i also noticed that when i called out dialing it as a local number, the log show a 40 connected to the front of the number.
    Any suggestions?
  2. iamcobolt
    Apr 22, 2011
    I am also having this issue Bump
