3Cx and Spa400
Gollum
I am having problems with a spa 400 gateway connected to our 3cx server on windows.
I can make outgoing calls from our phones but i can't get incoming calls.
How to debug and resolve the problem?
Probably very similar to a SPA-3102 X 4
While no longer "officially supported" here is the link to getting the 3102 to work.
http:/ /www.3cx.com/voip-gateways/linksys-spa3102/ - NO LONGER AVAILABLE
Probably some tips you can use in there.
And here is a link to a site where they set up a SPA400 for use with 3CX.
http://jaydiennetworksolutions.wordpres ... -ip-pbx-2/
Between the two, you should be able to figure out what is not configured correctly.
Getting Started - Admin
deanhbs
Get 3CX - Absolutely Free!
3CX
