3CX and sugarCRM
Discussion in '3CX Phone System - General' started by hosting, Mar 28, 2013.
  1. hosting
    Mar 28, 2012
    10
    Whenever I"m making a call, I receive this error (shown as in attachment)
    Can any one high light me, what is a correct format for phone number?
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    @hosting
    The format of the number is the problem. You have hidden the number - I assume for security reasons, which is understandable.
    You should AT LEAST provide an example number that does NOT create security issues, but DOES expose the problem so people can replicate and see the problem, and evaluate and suggest a solution.
  3. hosting
    Mar 28, 2012
    10
    Thanks for your reply
    the number start with our country code 65, continue with 8 digits of local phone number, the number display here is something likeL
    6568718911 <= this is one of my testing SIP line number
    65 country code
    68718911 is the phone number
    there is no "+'" sign or whatever....
  4. hosting
    Mar 28, 2012
    10
    And i'm using community edition, does it matter if i use community edition or commercial edition?
    Strange problem...
  5. hosting
    Mar 28, 2012
    10
    This is a bug from one of the CRM version.
    http://www.3cx.com/downloads/3CXCRM10.msi (3.1M size) -- Worked with SugarCE.
    http://www.3cx.com/downloads/3CXCRM.msi (4M size) -- Error.
    The 3.1M file also not prefect, I had problem use it with SageACT sometime ago, but I forgot what was the problem...
  6. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,449
    115
    Hi there,
    This is a bug introduced in the latest version. In order to solve the problem do this:
    1) Using a text editor open the file "%AppData%\3CX CRM Integration\3CX CRM Integration.ini"
    2) Look for the parameter "MinCallerIdLengthForScreenPopup=" and set the value 0, i.e. "MinCallerIdLengthForScreenPopup=0"
    3) Save the file and restart the CRM Integration module.
    That should fix the problem.
