3cx and Windows 2003 server - Apache error
Discussion in '3CX Phone System - General' started by signo82, Dec 4, 2007.
  1. signo82
    Dec 4, 2007
    Hi! How can I install 3cx on Windows 2003 server?
    i have downloaded the setup file and installed successfully,
    but when I try ti access to web interface it doesn't work,
    from localhost too. when I close explorer it says: "Apache error"
    What can I fix my problem?
    I install it on win xp and it work perfectly, but I need on Windows 2003 server
    Thank you!
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    The problem is if you already have apache or IIS already installed on the server.
    Then there will be two instances on the machine and a conflict occures.
    There have been several discussions about this problem and there are at least equal amount of openions.
    Try to take a look at this
    http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/conflict-with-iis-and-php-1062/?highlight=apache
  3. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    This conflict only happens if there is another PHP or Apache instalation. With only IIS instaled on server it should work(at least here does).
    Cheers
