3CX android IP phone IVR
Discussion in 'Android' started by shyamala123, May 9, 2011.
  1. shyamala123
    May 9, 2011
    Hi, anyone used a 3CX android phone and called an IVR? When I call, the call gets through, but when I press the digits for the options; it hangs up the call. Any idea what I'm doing wrong?
    -Shyamala
    11,116
    329
    I've used it quite a bit to access my 3CX voicemail (PIN etc.). There are some DTMF options in the settings, you could play with those and see if it makes may difference.
