3CX API InvokeCommand
Discussion in '3CX Phone System - General' started by plugworld, Oct 29, 2013.
  1. plugworld
    Oct 29, 2013
    In the 3CX v12 version of the API, there is a function called InvokeCommand
    public void InvokeCommand(
    string commandName,
    Dictionary<string, string> parameters
    It seems that we can send commands to the 3cx platform.
    What are the possible commands that the platform can receive ?
