3CX API PBXConnection
Discussion in '3CX Phone System - General' started by studio5, Oct 10, 2012.
  1. studio5
    Nov 12, 2010
    I'm trying to use the API of the new 11 version of 3CX.
    With previous versions I used the following method: PBXConnection() without passing any parameter and it all worked.
    Now the new PBXConnection method requires as input the 4 parameters: Host, Port, User and Pass.
    Can you tell me exactly what values I must use and from where I can take them?
    I tried to enter different values ​​but I always generates the exception PBXIsNotConnected without a specific reason.
    I tried with:
    - localhost, 5482, admin, admin
    - localhost, 5485, DbServ, pass
    - 127.0.0.1, 5000, admin, admin
    I will appreciate your help. Thank you.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    "new PBXConnection()" still works. it is equivalent of ("127.0.0.1", 5482, "", "")
