3CX API Phone Status
Discussion in '3CX Phone System - General' started by daverowland, Sep 2, 2014.
  1. daverowland
    Sep 2, 2014
    I am looking to see if there is a way of taking the details of all Extensions to see if they are Away/Busy/Available/Away2 and to see if there is a way of setting them grammatically? preferably with HTTP API ?
    I have an attendance/alarm system, I would like to be able to change the status of phones based on if the person/company is actually present in the building or not.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    HTTP API does not have this functionnality, but Call Control API has much more advanced capabilities.
    Please review the sample project and chm documentation from Call Control API page
    http://www.3cx.com/blog/docs/call-control-api/
