3CX API with PowerShell
Discussion in '3CX Phone System - General' started by Togadude, Jun 8, 2018.
  1. Togadude
    Jun 5, 2018
    11
    Hi all,
    Anyone successfully using the 3CX Call Control API with PowerShell?
    I've found some useful code on the forum, but I can't get it to work.
    Config: 3CX Enterprise 15.5 on Windows 2016 Enterprise with PowerShell 5.1
    The error I get is like this:
    Thanks!
    T.
  2. Togadude
    Jun 5, 2018
    11
    No takers yet?
    I got some better results with calling the DLL with 'Add-Type' instead of 'System.Reflection.Assembly' using the following code:
    Code:
    Add-Type -Path "C:\Program Files\3CX Phone System\Instance1\Bin\3cxpscomcpp2.dll"
    Requesting the properties like so:
    Code:
    [TCX.Configuration.PhoneSystem].GetProperties()
    returns the attributes, so on to connecting...
    Code:
    [TCX.Configuration.PhoneSystem]::set_CfgServerHost("127.0.0.1")
    [TCX.Configuration.PhoneSystem]::set_CfgServerPort("5485")
    [TCX.Configuration.PhoneSystem]::set_CfgServerUser("cfguser_default")
    [TCX.Configuration.PhoneSystem]::set_CfgServerPassword("******")
    [TCX.Configuration.PhoneSystem]::set_ApplicationName("CallViewer")
    All looking good.
    However, when trying to instantiate an object like so:
    Code:
    $3CX = [TCX.Configuration.PhoneSystem]::get_Root()
    it throws a "ConfigServer is not connected" right back at me...
    Hopefully ringing any bells now?
    Thanks!
    T.
    LtFrankDrebin and HLM 3CX like this.
  3. Togadude
    Jun 5, 2018
    11
    Making progress, succeeded in connecting.
    Even managed to load extension data in an object like this:
    Code:
    $Ext = $Tenant[0].GetExtensions() | where ID -eq 390
    The following changes the last name of the user (instantly!)
    Code:
    $Ext.Lastname = "Doe"
    $Ext.Save
    However, the following code does nothing :(
    Code:
    $Ext.UserStatus = "Away"
    $Ext.Save
    Still plowing away...
    T.
    craigreilly and HLM 3CX like this.
  4. HLM 3CX
    Feb 26, 2018
    6
    Nice!
    Did you get farther along in it?
    Thank you!
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,282
    67
    I have no experience with running code from PowerShell, but a little experience with Visual Studio.
    I don't know if this helps, but "UserStatus" does not accept a string as a value, but objects of type "UserStatusType" which is an enum class. Try assigning an int instead of a string, and I think the only 2 values are 0 = Available, 1 = Away.
    No much more I can pitch in though....
  6. Danny Lauwers
    Aug 30, 2017
    suddenly last night, we got this error:
    2018-06-14 17:43:43,513 [4] INFO _3cxSync.PBX3cxConnector [(null)] - phonesystem.root connected voor aanvraag GETDN
    2018-06-14 17:43:48,731 [4] ERROR _3cxSync.PBX3cxConnector [(null)] - TCX.Configuration.Exceptions.PhoneSystemException: ConfigServer is not connected
    at TCX.Configuration.PhoneSystem.Connect()
    at TCX.Configuration.PhoneSystem.get_Root()
    at _3cxSync.PBX3cxConnector.Initialize(String applicationName, String version) in C:\Projects\WPF\Domus Admin\DaMainServicePlugin\3cxSync\PBX3cxConnector.cs:line 82
    2018-06-14 17:43:49,160 [4] INFO _3CXSyncService.Sync [(null)] - ConfigServer is not connected
    Had been working perfectly ?
    User/password are correct.
    Could it be that there was a 3CX/windows update that causes this ?
    Any idea on how to resolve this error ?
    Hope you can help !
    Danny
  7. LtFrankDrebin
    Mar 17, 2018
    16
    Hey Togadude,
    just stumpled upon your post because i am trying to set up some routines started from powershell.
    What can i say, you already assumed, it does not work for me.
    I actually am only trying to get a sample running which makes a new phone book entry.
    Do you have a simple (complete w/o passwords) example of how you get your code running?
    Thank you very much for your efforts!
    Andreas
