3cx api
Discussion in '3CX Phone System - General' started by octopus, Jun 2, 2009.
  1. octopus
    Apr 7, 2009
    I am examining the 3cx software to see if it feals my needs
    I need to know if the API of 3cx supports my needs:
    1. call is received by 3cs server
    2. 3cx server takes data from my applications and accordingly selects a Digital Receptionist.
    3. 3cx server sends data that the caller entered into my application
    This functionality essensial for me so please I need an answer or a direction.
    thanks
  2. zensoftware
    zensoftware New Member
    Aug 23, 2007
    225
    Hi Octopus,
    The short answer is no.
    The slightly longer answer is that only step 2 wont work. 3CX routes a call to a DR based on the number dialed or by some internal route goverened by the behaviour you configure within 3CX. It's not possible to route call based on data from an external application.
    I hope this helps.
    Emmet.
  3. octopus
    Apr 7, 2009
    Thanks Emmet for the reply, I understand your answer so let me rephrase my question
    When a call is made, The Digital Receptionist is supposed to be made according to my application's DB, so I need a workaround to do that - maybe my app can change the voice file of the Digital Receptionist or something like that?
  4. zensoftware
    Aug 23, 2007
    225
    I'm note sure it's possible.
    The calls come in via a SIP trunk (for example) and are then routed by 3CX accordingly, I think you would have to have an app that registred the SIP trunks itself, pickup the inbound caller ID, mathed with data in your DB and then placed the call directly to the extension on the corresponding DR.
    I think really the basis of the API is to allow existing calls on the system to be manipulated, ie transferred, dropped etc. I dont think it allows you to route calls that haven't yet arrived on the system.
    I could be wrong though, I'm not a software engineer.
  5. octopus
    Apr 7, 2009
    I am not interested in routing a call
    I want to get input from the caller to my DB and thats it
    The caller should listen to a Digital Receptionist according to my DB and the input it's choice and then the call ends.
    do youknow anyone that I can ask this question in 3cx?
  6. octopus
    Apr 7, 2009
    Please can some one help me?
  7. zensoftware
    Aug 23, 2007
    225
    Ok, I think I know what you need now.
    A called calls in the the DR, there are 3 choices. The caller chooses option 2, then hangs up, that choice is then recorded ni the DB.
    Is that what you want?
    If so you may have to employ the MS Exchange integration as the only thing you can get 3CX to pass to a DB by default is the CLI of the caller.
    Regards,
    Emmet.
  8. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,361
    109
    You will be able to do it very soon (Q3 2009).
    Take a look at this whitepaper (10. Easily build voice applications that increase productivity):
    http://www.3cx.com/white-papers/ - NEW LINK
