3CX API
Discussion in '3CX Phone System - General' started by jwnesbitt, Feb 27, 2011.
  1. jwnesbitt
    Sep 19, 2009
    48
    HI
    Is there an API available for 3CX.
    I would like to get an Addin developed for Windows Home Server 2011 so that 3CX will intergrate into the desktop
    Jody
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    There are a couple of api's with the call control being the main one and the CRM Plug in api being the other.
    What are you trying to achieve?
    Also in V10 the assistant is going to silverlight and there will be a desktop based Myphone (though it is not finished yet so no-one outside of 3cx knows exactly what is in it).
