3cx Api
Discussion in '3CX Phone System - General' started by darthzejdr, Nov 9, 2012.
  1. darthzejdr
    Feb 20, 2012
    17
    hi,
    I've done a few applications using 3cx api / 3cx database connection. I have a customer that needs a new feature and i'm not sure if it can be done.
    He needs to be able to run a command/program/something when a user picks something in ivr.
    So basicaly, use call the number, ivr responds, and then if the user presses something(for instance 5) a specified program is run.
  2. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    This may be something that the Voice Application Designer [3CX - VAD] can do ...
    Manual is here ... http: //www.3cx.com/manual/3CXVADManual3.pdf - no longer available
    I have had a VAD project put together that is able to capture data from DTMF tones, input it into text, and create e-mail's ... Have a look at how VAD works and see if that gets you closer ...
    [And there is a separate Forum running for VAD related questions.]
    Bets regards
