3CX APP 1.1.4 Iphone Multitasking
Discussion in 'iOS' started by energie22, Dec 1, 2011.
  1. energie22
    Dec 1, 2011
    Hallo, nutze die 3 CX APP 1.1.4 mit Sipgate, meine Iphone 4 ios 5.0.1. Unter meinen Einstellungen in der App ist das Multitasking aktiviert. Schliesse die App dann und normalerweise sollte Sie dann im Hintergrund ständig laufen und das tut Sie nicht, also keine ständige verbindung mit dem Sipgate Server. Bin für eine halbe Stunde bis Stunde erreichbar.
    Hi use, the CX 3 APP 1.1.4 with Sipgate, my iphone 4 ios 5.0.1. Among my settings in the app multitasking is enabled. Close the app and then you should normally be run continuously in the background and you do not, so no permanent connection to the Sipgate server. Am for a half hour to hour away.
  2. RandyChev
    Nov 4, 2011
    15
    Not sure if this is the issue but I'll add to it with my similar situation. We have two users using iPhone app 1.1.4 on an iPhone 4 and 4S. Both users have reported that the apps unregister when in the background over time. No scientific measurements to determine what causes or when it happens. The have Multitasking mode selected. Any ideas for keeping the app registered?
  3. andsyd
    Mar 20, 2012
    This happens here to.
    Tested on 2 phones. 3CX unregisters after a phone has been locked for a while.
    Multitasking is enabled (but not working).
    iPhone 4
    IOS 5.1
    3CX 1.1.4
  4. albertc
    Nov 21, 2011
    89
    There is a limitation on how apps work in the "Background" in iOS. When a running application is pushed to the background in iOS4 or higher, it is put into a suspended state. It is not actually ‘running’ any more. Because the app is in a suspended state, it won’t impact the performance of an application running in the foreground nor will it consume a lot of battery. More importantly, for a VoIP application like 3CX for iPhone, the application cannot perform any actions for a minimum of 600 seconds. This means the app cannot perform any SIP registrations, keep-alives, or other actions that a VoIP application normally executes in order to maintain connectivity. Apple did provide support for the maintenance of TCP-based connections for VoIP applications while in the background however. Try switching to TCP transport if your PBX support it.
  5. albertc
    Nov 21, 2011
    89
    Sipgate has it own app in Apple App Store.
  6. StefanW
    Jun 2, 2009
    1,230
    95
    fixed in upcoming version
