3CX app and switching between bluetooth/speaker/speakerphone
Discussion in 'Ideas' started by Shane Farmer, Nov 7, 2017.
  1. Shane Farmer
    May 15, 2017
    24
    I might be in the minority, but in my particular use case, my Bluetooth phone calls aren't relayed through the audio system in my car, or say I want a private call, even if it was. At this time, if I take a call with 3CX app on Android, it connects to Bluetooth if my Bluetooth is on, and I can't here them unless I disable Bluetooth completely on the phone.
    In the Samsung Phone and Android Phone apps, it connects to Bluetooth initially, but there is a button in the Phone UI that shows Bluetooth and when I click it, it changes to cell phone speaker. Right now I have to open the phone UI and disable Bluetooth completely, then I can hear audio through phone speaker.
    Thread referencing my issue:
    https://www.3cx.com/community/threads/toggle-bluetooth-on-android-client.51237/
    Android 7.0
    Samsung S8 currently
    Andoid 7.1.2 LineageOS
    Samsung S5 previously
    Same issue with both.
