3cx app for iPad
Discussion in '3CX Phone System - General' started by runnerpaul, Dec 19, 2013.
  1. runnerpaul
    Nov 22, 2013
    25
    I have setup the 3cx and tunnel apps for the iPad but they won,t work.
    I think the 3cx app is OK as I can use it when in the office(connected to the office network), but when I am out of the office I am unable to connect.
    The Tunnel app status shows stopped or connection pending.
    I think I have it configured correctly. Do I need to make any provision on the firewall?
    Paul
  2. runnerpaul
    Nov 22, 2013
    25
    By the way, I have the following ports open and forwarded to 3CX for both TCP & UDP
    5060
    5090
    9000-9049
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,128
    207
    Can the extension connect from outside the LAN?
    I haven't used the tunnel much - almost all networks I have been on just work.
  4. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    More info needed. Too vague.
    What are you connecting to when not on the LAN, WiFi hotspot? Mobile data carrier?
    What ports are mapped on the router where 3CX is located?
    Nat helper on? Stun?
    Did you provision the IoS device on the WiFi network in the office using 3CX or did you do it manually?
  5. runnerpaul
    Nov 22, 2013
    25
    Hi sigma1,
    Please see my responses:
    I have tried both.
    5060
    5090
    9000-9049
    oh and 5000.
    Where do I check this?
    I provisioned it in the office.
