3CX App iPhone Forbidden Calls
Discussion in 'iOS' started by nfedei0522, Jun 26, 2012.
  1. nfedei0522
    Jun 26, 2012
    5
    All:
    I have installed 3CX and utilizing the iPhone app. I am not having any making phone calls as it continuously says forbidden. Internal extension or external dialing. Doesn't matter. All forbidden. Here is a copy from the server logs.
    14:48:44.207 [CM503013]: Call(10): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 103@24.120.119.213:5060 tid=PjSm6OCBK1Skw-6JeB.xJYbA6gL9iaQCh1 cseq=INVITE contact=100@24.234.42.140:5065 / 4345 from(wire)
    14:48:43.843 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:103@24.120.119.213:5060 SIP/2.0
    Via: SIP/2.0/UDP 24.234.42.140:5065;rport=5065;branch=z9hG4bKPjkEs-xwPg6V7F8jvtTEqknXu6PqUzVo38
    Max-Forwards: 70
    Route: <sip:24.120.119.213:5060;lr>
    Contact: "Nicholas Fedei"<sip:100@24.234.42.140:5065;ob>
    To: <sip:103@24.120.119.213:5060>
    From: "Nicholas Fedei"<sip:100@24.120.119.213:5060>;tag=8mbsaTzXw5VMZbiG7sZBIDUzZV6sXR2H
    Call-ID: O97ywOn76caEdKh66VB8.1DwO8RWuul8
    CSeq: 4344 INVITE
    Session-Expires: 1800
    Min-SE: 90
    Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
    Supported: replaces, 100rel, timer, norefersub
    User-Agent: 3CXPhone for iPhone 1.1.5
    Content-Length: 0
    What am I missing here??
    Thanks for you help!
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    Is the phone trying to make a call from OUTSIDE the network. It seems like that is the case as I see different IP addresses.
    In the extension setup for 103 - do you allow calls from outside the LAN ?
  3. StefanW
    Jun 2, 2009
    1,236
    96
    correct,
    the local SIP domin in your 3cx phone system is not set to "24.120.119.213"
    Internaly we can read form the NIC the IP and if this matches the Invite we grant the call.
    But your Public IP we dont see on the local NIC, so once you come from external we will block you.
