Solved 3CX App on IOS 11
Discussion in 'iOS' started by Delo123, Oct 5, 2017.
  1. Delo123
    Sep 12, 2017
    14
    We are trying to install the 3CX App on Iphones with IOS11, but that doesn't seem possible. Also there isn't any reference to it when it will be supported. Someone have an idea?
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    13
    Can you provide more information ?
    Did you receive any error from the app store?
    What iPhone model are you using?
    Thank you
  3. Delo123
    Sep 12, 2017
    14
    New Iphone 7's, one clicks on the app in the appstore and the circle starts turning but nothing happens. All (same) IOS 10 devices work flawlessly. I won't dare updating a IOS 10 with the app installed to 11 since we would lose another phone that way currently. Can you try to install the app on a IOS 11 device internally? We tried the german and dutch appstore (not sure if that makes a difference)
  4. Marios Neophytou
    Mar 1, 2016
    258
    13
    It should not be any problem on any store but did you try to install another app? Works fine for me internally
    Thank You
    Delo123 likes this.
  5. Delo123
    Sep 12, 2017
    14
    Yeah, other apps and browsing were just fine. We tried for over 2 hours yesterday. Will ask again a colleague later today, but i thought before trying a lot of things to get confirmation it's ok on 11 (clean install, not update)
  6. Marios Neophytou
    Mar 1, 2016
    258
    13
    I have also installed the app with a clean account. No problem at all.
    Can you make some basic troubleshooting, such as sign in / sign out from the app store or restart the phone and try again.
  7. Delo123
    Sep 12, 2017
    14
    Yeah, those was the stuff we tried yesterday, will do again later and let you know!
