3CX app on Xperia x10i 2.1
Discussion in 'Android' started by chowdarygm, Nov 2, 2010.
  1. chowdarygm
    Nov 2, 2010
    Hi all,
    updated the xperia x10i to 2.1 and when using 3CX app to call using my SIP provider, the other person is getting very loud echo on his side for his own voice
    i have tried using the echo cancellation settings but nothing worked
    the echo on other side will be cancelled only when using headset with the phone
    when used with same account and 3CX on my nexus, there is no echo and sound is very clear on both sides
    can anyone tell me how to solve this as this is creating a huge inconvenience to use this app
    thank you
  2. Sarah Hastings
    Nov 24, 2010
    15
    Does the echo occur with every call and whose voice echos your or his? Anyway my experience showed me that this can occur over some networks...It is very probable that if you are hearing your echo then the receiving end's network is at fault and if the receiver's end hears his own echo through then your network is at fault.
