3CX as IVR
Discussion in '3CX Phone System - General' started by alto, Jul 14, 2010.
  1. alto
    Jul 14, 2010
    Sorry if it was answer before, the search didn't helped me her.
    Is it possible t use the 3CX as IVR? if yes, how?
    10,835
    294
    It does have an IVR feature (the digital receptionist) available to direct callers to certain extensions or ring groups (departments). The "how" would all depend on exactly what you were trying to achieve.
  3. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    You can do anything you want with 3CX!!!! :mrgreen:
    Seriously though, you can do this. You can have 3CX terminate your inbound calls as an IVR and divert calls through to different sources. How you would do this will depend on what your exact application is. If explain what you want to do, maybe we can provide a more insightful response,
