3CX as Software as a Service ** SIGMA VOIP SOLUTION PROVIDED
Discussion in '3CX Phone System - General' started by smarteruk, Jan 1, 2010.
  1. smarteruk
    Oct 1, 2008
    10
    Is anyone running the 3CX System as Software as a Service SaaS?
    Cheers
    Richard
  2. bhall
    Dec 23, 2009
    Re: 3CX as Software as a Service
    Hello Richard;
    Our company is in the process of deploying this model. We are still developing the business rules but our market research shows if you can get the right VoIP package and combine it with 3CX, you'll have a powerful solution if the price is right.
    Cheers;
    Bob
  3. smarteruk
    Oct 1, 2008
    10
    Hi Bob
    I am actually after the solution, so would you have anything we can use / trial /beta?
    I have been looking through 3CX and was about to deploy it, and have probably decided that I am going to go down the SaaS route as we do for our other business needs. We currently use Numberstore for number routing and Voipfone for actual sip extensions...
    Cheers
    Richard
  4. smarteruk
    Oct 1, 2008
    10
    Has anyone done this yet?
  5. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    http://www.3cxcloud.com
    Beta testing done, production trials completed, open to the public within the week. Completely private, dedicated 3CX.
    110% dedicated bandwidth (guaranteed set-aside), 3 state of the art fully owned (not co-located) data centers. Servers and SAN running on Raid 10 on 10Gbps backbone.
    Several connectivity options ranging from open IP connectivity to EoIP to VPN.
    Every support engineer is 3CX Certified and the parent company is a 3CX Premium Partner.
  6. smarteruk
    Oct 1, 2008
    10
    Any more news on the launch?
