Solved 3cx asking to update via email
Discussion in '3CX Phone System - General' started by nitrox, Feb 2, 2017.
  1. nitrox
    Sep 10, 2016
    88
    11
    everyday i am getting emails notification to update my 3cx pbx (linux version 15.0.61673.0 NFR license). If I login inside the pbx there isn't any update available. If I force the system to update the reply is that the pbx is already updated.
    It seems that i cannot update the pbx anymore or the system is already updated but it is still sending email to update for some reason.
    Is there a way to know which is the last minor beta update available for 3cx?
    Is it true that i am running the last minor bug update of the pbx?
    thank you
    paolo
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @nitrox
    Are you running the Windows or linux version?
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    At least we could receive email with some general change log(to pay more attention on changed features) and instructions for manual update:
    https://www.3cx.com/community/threads/bug-fix-linux-version.47001/
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Try upgrading packages via Debian.
  5. nitrox
    Sep 10, 2016
    88
    11
    hi,
    i have forced the system via ssh with:
    apt-get update
    apt-get upgrade
    and now it is upgraded correctly. It pass from 15.0.61673.0 to 15.0.62395.5. With the version 15.0.61673.0 was not working the apple push notification anymore (google push service was working instead) and i had to upgrade manually to bring back the service working.
    Now everything is working fine.
    paolo
    #5 nitrox, Feb 8, 2017
