3CX Assistant across Multiple Systems
Discussion in '3CX Phone System - General' started by packetwire_59, Jul 9, 2010.
  1. packetwire_59
    Jun 30, 2010
    25
    Hi All,
    This may seem like a silly question, but is possible for 3CX assistant to show presence for a remote system? for example, we have two systems deployed in our corporation, but we wanted to have a central receptionist take calls for both locations and dispatch them accordingly via the assistant.
    Thanks,
    Rick
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi Rick,
    v9 provides this functionality.
    If you have further questions/comments, please post them on http://www.3cx.com/forums/3cx-phone-system-version-31/
