3cx Assistant and Iphone SIP phone
Discussion in 'Windows' started by rico06, Oct 20, 2009.
  1. rico06
    rico06 New Member
    Jan 11, 2008
    143
    I instal a SIP client on my iphone and it works perfectly, I use it on the same LAN (did not try out)
    But if I use call assistant and I dial from it I have no audio receive to my iphone, if I use 3CX softphone instead of my iphone no problem
    I dont see what can be wrong on the setting of my iphone !
    probably the best could be to have a iphone 3CX softphone but in the meantime...
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    What softphone are you using on the iPhone?
