- Joined
- Nov 12, 2009
- Messages
- 32
- Reaction score
- 0
I just upgraded to the 8.0.9924 assistant and it looks like it doesn't work with the very latest 3CX system. I had to upgrade. it "works" now. BUT!!
After the upgrade all the external calls say INTERNAL CALLS. I have check all my network and PSTN settings and there is nothing that will indicate 3cx that external are internals. I would like to report this to 3cx as a bug but all I see on this site is COMMERCIAL SUPPORT to get support. I don't need support I need to report something that might be wrong. what is the procedure to report this kind of things?
Best regards
Guillermo Dewey
http://www.ofik.com
Best regards
Guillermo Dewey
http://www.ofik.com
