3CX Assistant bug
Discussion in 'Windows' started by igor.snezhko, Dec 6, 2009.
  1. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    It would probably help to provide as much information as possible such as OS, version, service pack, system configuration, what version of the 3CX Assistant, and anything else you can think of.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    This message appears when you have installed the Assistant without the VoIP phone but in the Assistant Preferences you have it set to use the VoIP phone for Dialing numbers.
    You need to go to Preferences > Dialing > Make calls by PBX.
    If you want to use the VoIP phone options you need to install the VoIP phone along with the assistant during the installation.
  4. igor.snezhko
    Jan 7, 2008
    668
    7
    Interesting that 3CX Phone was running at time of this bug.
  5. LeonidasG
    Nov 19, 2008
    1,557
    118
    That's odd...
    Anyway we have fixed this, and it will be available in a future Update.
