3cx Assistant - Cannot get it to work properly
Discussion in '3CX Phone System - General' started by bsmcy, Jan 29, 2010.
  1. bsmcy
    Jan 28, 2010
    I cannot get the 3cx assistant to work properly although the 3cx phone works great. It gets connected on the server, but either than that it does not do anything else. I create groups on the server but still it shows me all created users under "Not group members" and all of them are shown as 'not registered' , although all members are connected through the 3cx phone and talk to each other properly. By the way, I am using the latest free version for testing purposes. Any suggestions how to get the assistant to work properly?
  2. andymars
    Jan 12, 2010
    47
    i have a similar issue after upgrading the server to 8.0.10116.583.
    3cx assistant version is 8.0.9924.0
    although the 'executable version' says 8.0.0.9921
    EDIT - will try new versions as detailed in this new post
