3CX Assistant F11 key problem.
Discussion in '3CX Phone System - General' started by sssputnik, Apr 21, 2010.
  1. sssputnik
    Apr 21, 2010
    28
    The use of the F11 key in the 3CX Assistant is causing us issues due to it conflicting with our development software.
    Is there a way to change it from F11 to another key?
    Thanks,
    Simon Shaw.
  2. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Yes,
    of course open Call Assistant, File > Preferences > Dialing and change the hotkey from F11 to one you would like to use.
  3. sssputnik
    Apr 21, 2010
    28
    Duh! OK thanks heaps for the quick reply.
