3CX assistant fails to connect to server
Discussion in 'Windows' started by ChameleonPaul, Feb 16, 2010.
  1. ChameleonPaul
    Jan 11, 2010
    11
    Hi.
    Recently downloaded, and now trialling, the PBX.
    PBX seems OK, but 3CX assistant not connecting. Server details are correct. Ports are open. (no firewall on server. 3cx does not even connect when runn on server / localhost.)
    Any clues?
    Are there connection limits/restrictions and where?
    Ta
  2. ChameleonPaul
    Jan 11, 2010
    11
    Ahh... Think I may have answered my own qu... I have downlaoded the free version... Does 3cx assistant even work in free version?
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,889
    190
    Yes, the 3CX assistant works in the free version but only provides limited information. You will such a message shown in the display of the 3CX assistant (that it is a free edition and info is not available)
  4. skagen
    Mar 30, 2010
    35
    TA, I had the same issue. My problem turned out to be the wrong port assigned under the file -> preferences -> advanced.
    it should be 5486. Also double check in the extension settings that you have the pin number set and you know what it is.
  5. synapsenetworks.com
    Dec 19, 2008
    I have bumped into this problem and it transpires, with the help of 3CX, that it is an issue with A/V. In particular ESET Nod32. If you toggle to advanced setup>Real-time file system protection>Threatsense engine>extension and then take the tick out of "Scan all Files" all will work beatifully. ESET is still scanning waht they deem the most vulnerable./important file extensions.
    This issue does not seem to appear in all versions of the call assistant.
    Hope that helps
    Matt :p
  6. mart3cx
    Jul 1, 2010
    19
    i have the same problem with version 8.011114.0.
    The preferences are set correct (correct ip of server, port 5486, username, passwort, ..) but i always get message "error while connecting to server".
    The assistant has already work, but for some weeks it suddenly stopped working. I have already turned off windows firewall and AV. Also on the 3cx server is no firewall running.
    I have also restarted all services of 3cx.
    Phones an all other services are running normal.
    Could anyone help?
    tx
    Mart
  7. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Are you running some kind of antivirus on there, if you are try remove. The reason being that certain unintelligent virus scanners tend to give the assistant grief as it is slightly over worked, more often then not removing the virus scanner eliminates this problem.
  8. pluteus3300
    Jul 9, 2009
    Thanks synapsenetworks.com for the tip with Eset!
    Did the trick for me too!
    Regards
    Martin
