3cx assistant lost connection
Discussion in '3CX Phone System - General' started by paullf, Feb 15, 2011.
  1. paullf
    Jun 18, 2010
    7
    Help, our 3cx assistant keeps loosing the connection with the host computer so we dont have the pop up window when a call comes in, we cant use the F11 button. This is happening numerous times during the day. we connect via a tunnel and we know that its not the line because my colleague in a completely different office has the same problems and the only thing that links us both is the 3cx host computer.
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    It sounds like your firewall may be dropping the connection after so long.
    Go to File > Preferences in the assistant. On the advanced tab check the Force Refresh Every: minutes box and set a suitable time. Try 15 minutes at first then extend it if it works until you get something useful and doesnt time out.
