3cx assistant service memory leak ?
Discussion in '3CX Phone System - General' started by ndl, Dec 7, 2009.
  1. ndl
    ndl
    Nov 5, 2008
    51
    Is there a memory leak in the assistant service?
    I’ve noticed it slowly keeps taking up lot and lots of available memory
    This morning it had a private working set of just over a 1G and when I restarted the service it dropped down to around 150M
    martin
  2. ndl
    ndl
    Nov 5, 2008
    51
    shoiuld of said we are using version 8.0.9941.549
  3. ndl
    ndl
    Nov 5, 2008
    51
    now upto 365,244K since last message submit
  4. ndl
    ndl
    Nov 5, 2008
    51
    now upto 793,960K
    attached are 2 images from perfmon which is monitoring the assistane process they are 5 minutes apart
  5. pjr
    pjr New Member
    Oct 5, 2009
    154
    A New version of 3CX exists that fixes this problem (we had the problem too - the amount of memory goes up every time a call comes in and never gets released)
    http://wiki.3cx.com/change-log/build-history-changelog
    Build Version 8.0.10116 26 November 2009
    * Fixed: Call Assistant Server performance problem
    * Fixed: Internal lock in service
    * Fixed: Devices / phones recognition (devices.xml)
    * Fixed: CDR output showing incorrect date format
    * Fixed: CDR Missing calls
    * Added: CBeyond template
    * Added: Outbound rule match with no prefix and range of extensions (Example 100-999)
    * Added: Backup check in Backup and restore
  6. ndl
    ndl
    Nov 5, 2008
    51
    thanks for your pjr, guess I'm going to have to allocate some time to reinstall our live system.
  7. pjr
    pjr New Member
    Oct 5, 2009
    154
    Annoying, I know but shouldnt take too long.
    Just be wary in case you have amended the original phone provisioning templates without renaming them, as any changes will be lost (likewise with any amendments made to the 3cxphonsystem.ini file).
    Paul
