3CX Assistant should not open/close its log file so often
Discussion in 'Windows' started by o.mascia, Apr 7, 2009.
  1. o.mascia
    Oct 6, 2008
    14
    ( Regarding file: tcx.assistant.client.exe.log )
    It better should keep the log file opened and write to it as needed, or drastically limit the number of lines written to the log file. Users with anti-virus solutions set to scan all files see sometimes hyper-activity in their anti-virus product, all targeted at scanning and rescanning that same file again and again.
    It is indeed probable that sometimes 3CX Assistant starts going mad writing very quickly / often to that log file. It may be bug related or even beta related. Though even when things look stable, it opens/writes/closes much more than once a second. This is *the* file ranking the top scans per minute here. Seen on multiple users computers, each run either Kaspersky or NOD32. Excluding files in .log from scan is not accepted. Excluding only that 3CX Assistant file is acceptable but a real pain.
    This is not terribly sad, except that users have taken the habit to just stop using 3CX Assistant as soon as their computer starts eating cpu. And as stopping 3CX Assistant magically stops the issue they are having, they learn, quickly and bad habits will be hard to fight later.
    Just a suggestion,
    Yours,
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    Hi, Matt
    Matt, please ask your colleague to provide you - then please tell me - the VoipPhone version nr and its logfile name and size, also with CPU usage.
    I have a special reason to check this - by default, VoipPhone does not log anything on files (traces on its Debug window are not logged, they are "volatile").
    Thanks 8)
    vali
  3. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Hi, Matt
    My mistake - then I extend my question to the Voip Client also :mrgreen:
    On the other hand, I want to avoid a confusion here: disk writes are not the same with disk opens. Watch me:
    scenario 1 - open file; write log, write log, write log, close file.
    scenario 2 - open file, write log, close file; open file, write log, close file; open file, write log, close file.
    As long as I know, both Voip Client, Voip Phone - ok, let's include also their tunnels - works in "scenario 1" mode, therefore they meet o.mascia's proposal "It better should keep the log file opened and write to it as needed".
    Regards
    vali
