3cx assistant showing connected, not registered
Discussion in '3CX Phone System - General' started by rmorock, May 24, 2010.
  1. rmorock
    May 22, 2010
    5
    I am using the latest version of the call assistant
    the system shows that it is connected to server but showing that the extention is not registered.
    I am using the 3cx phone and can dial out and get calls.
    Please help
    Roy M.
    Roy Morock Computer Support
