3cx assistant v9.0.15208 phonebook error or BUG
Discussion in 'Windows' started by bluetel2, Nov 29, 2010.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    Hi all,
    i have installed the last version of 3cx assistant. when i want to call number from phonebook i write "name " on call pop up and 3cx assistant print "nick name name - number" and compose. but today with last version 3cxphone don't compose number but compose "nickname"...
    v9 sp4 and the last version of 3cx assistant and 3cxphone.
    tks advance
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    Hi all,
    i'm the only man with this bug ?
    no one see this ? :'(
  3. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    so i'am the only man with this problem ?
    i will try to explain
    in general phonebook, I have insert phonenumber like "Germain is name, and him number phone (mobile) 06 66 66 66 66".
    in 3cx assistant, before last version, when i write Germain server propose germain - 06 66 66 66 66 and make call to him, but today when i do this server said "the composed number is not attribuated, and server log said
    10:41:48.256 [CM503007]: Call(253): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=96d257236cbf1c4a
    10:41:48.256 [CM503007]: Call(253): Device joined: sip:131@192.168.1.77:1097;rinstance=d2bd0c2c217c0ef2
    10:41:48.241 [CM503002]: Call(253): Alerting sip:EndCall@127.0.0.1:40600;rinstance=96d257236cbf1c4a
    10:41:48.100 [CM503025]: Call(253): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=96d257236cbf1c4a]
    10:41:48.069 [CM503016]: Call(253): Attempt to reach <sip:germain@192.168.1.42:5060> failed. Reason: Not Found
    10:41:48.069 [CM503014]: Call(253): No known route to target: <sip:germain@192.168.1.42:5060>
    10:41:48.053 [CM503010]: Making route(s) to <sip:germain@192.168.1.42:5060>
    10:41:48.053 [CM505001]: Ext.131: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:131@192.168.1.42:5060]
    10:41:48.053 [CM503001]: Call(253): Incoming call from Ext.131 to <sip:germain@192.168.1.42:5060>
    tks advance for your help
