3CX Assistant with Outlook in Exchange configuration
Discussion in '3CX Phone System - General' started by garethb_83, Jun 4, 2009.
  1. garethb_83
    Oct 11, 2007
    25
    I noticed in the Known issues of current 3CX Assistant there is an issue with it resolving outlook clients when in exchange mode.
    Is there any workaround so outlook can resolve incoming CLI to existing contact within outlook?
    It says its a permission issue so can I change what ever permission to get it working?
    Any Help would be good as this is one of the advantages for 1 of my clients which are currently trialling.
    Gareth
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,254
    97
    The latest version fixes that problem.
    http://wiki.3cx.com/change-log/3cx-assistant-build-history
  3. garethb_83
    Oct 11, 2007
    25
    Seen the new version. Thanks... I've started to visit he download page every couple of days to see if there are any updates. Would be nice if we had notification in an email..
  4. GasperS
    Jul 6, 2009
    14
    I installed the new version of assistant (7.1.3438.0). We also have the latest version of 3CX server installed (7.1.7139.0) but 3CX assistant still doesn't pick callers from our exchange (exchange 2003).
    For users connected to 3CX PBX name is also shown, but for other users only caller number is shown.
    The only way, I managed to display caller name was to create my own phone book in outlook, then enable CRM integration. This way caller name is displayed in CRM pop-up window.
    Am I missing something?
  5. edossantos
    Jun 27, 2007
    1,254
    97
    You need to have the exchange folder mapped in your Outlook, and enable CRM Integration, configuring it to look for contacts in the Exchange folder.
  6. GasperS
    Jul 6, 2009
    14
    Can you please explain how to map an exchange folder to outlook?
  7. edossantos
    Jun 27, 2007
    1,254
    97
    When you are connected to Exchange with Outlook you can see shared folders in Exchange.
    Those shared folders are listed in the Outlook Plug-in configuration of the CRM Integration module. You need to check the folder where you want to look for contacts in Exchange. This is explained in detail in the CRM Integration user's manual. You can take a look at it at http://www.3cx.com/manual/3CXAssistantCRMIntegrationManual.pdf.
  8. GasperS
    Jul 6, 2009
    14
    Thank you for your help Ernesto.
