3cx assistant
Discussion in '3CX Phone System - General' started by POTI, Oct 11, 2010.
  1. POTI
    May 19, 2010
    7
    For some odd reason it did not install 2cx assistant when I did the v9 install. How can I get this installed now?
    POTI :?:
  2. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    You need to uninstall the old version of 3CX call assistant (version 8?), and then install Call Assistant for version 9. You do not usually install call assistant on the computer running 3CX.
    Kind regards
    Richard Crabb
  3. POTI
    May 19, 2010
    7
    Ok so where do I download the 3cx Assistant installer?
    Phil
  4. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Hi, Download from this link - http://www.3cx.com/downloads/3CXAssistantSetup9_14081.exe
