3CX Asst - What versions of Outlook is it compatible with?
Discussion in '3CX Phone System - General' started by pjr, Nov 13, 2009.
  1. pjr
    pjr New Member
    Oct 5, 2009
    154
    As per the title?
    does it integrate with
    XP
    2003
    2007
    Versions of Outlook?
    Paul
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,582
    115
    To answer your first question.
    Yes.
    To answer your second question.
    2003 and 2007
